Walnut Oil Users - Question
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=10834
Author:  Bobc [ Fri Feb 09, 2007 7:27 am ]
Hesh the stuff you bought is great for salads and other foods. I think the cheaper stuff would work just fine as would olive oil which is also good in salads.
Author:  TRein [ Fri Feb 09, 2007 7:37 am ]
Get out your balsamic vinegar, Hesh. You'll be eating lots of salads. The "roasted" walnuts make me worry a bit. Probably good for flavor, but a big ? when it comes to polishing. Whole Foods had the Spectrum brand the last time I was there and it is just cold pressed walnut oil, which is what we are after.
Author:  crazymanmichael [ Fri Feb 09, 2007 8:07 am ]
i use the hain and have had no problems.
Author:  TRein [ Fri Feb 09, 2007 10:57 am ]
The Hain has additional additives, vitamin E I believe, to retard spoilage. The word I read somewhere is that the additive is not a good thing. But if Michael is having no probs with it then it may just be one of those "luthier myths" that float around. Still, I would use 100% cold pressed oil with no additives if given a choice.
Author:  Joel [ Fri Feb 09, 2007 12:59 pm ]
That Roasted Walnut oil looks really tasty Hesh. Bet it'd make your guitar smell great too!
I've been wondering if Macadamia Nut oil would be any good? I seem to remember reading that the reason walnut oil was good for french polishing was that it would evaporate unlike olive oil which needs to be spirited off. I don't know if macadamia nut oil evaporates, but it would also make a nice smelling guitar! (and tasting... although you'd probably get a few strange looks if people saw you licking your guitar )
Author:  jhowell [ Fri Feb 09, 2007 1:28 pm ]
Hesh--
It's sounding like you are getting ready to get some exercise! I've found a good source for sandarac and copal for my experiment -- The Gemmary -- and have a small order in.
Let me know when you have a spare hour or so and we can get together.
Author:  jhowell [ Fri Feb 09, 2007 2:02 pm ]
Hesh--
What I ended up doing was based mostly on the fact that I finished the neck with Tru-Oil. I did the finish to both the neck and guitar body prior to installing the neck. I didn't tape the bridge area or the fretboard extension as my intuition was telling me I wanted as few obstructions as possible in the motion of the pad. In hindsight I think that this worked pretty well and I'll do it this way next time. It takes a little extra time to scrape, but not too bad.
Looking forward!
Author:  CarltonM [ Fri Feb 09, 2007 2:13 pm ]
Hesh,
The alcohol in the shellac will dissolve the tape's adhesive, and incorporate it into your FP. I know this to be true.
Also, if you've got a Woodcraft near you, check there for walnut oil--it's supposed to be the straight-up stuff. If they don't have it, get it from Lee Valley. It's easy!
Author:  crazymanmichael [ Fri Feb 09, 2007 3:02 pm ]
considering that a coniferous top does not need filling,and you are going to french polish, why not use a darker shellac to achieve the colour you want?
Author:  crich [ Fri Feb 09, 2007 3:23 pm ]
Not to hijack this thread, but is sandarac and copal for hardening of the finish? Clinton
Author:  jhowell [ Fri Feb 09, 2007 3:35 pm ]
The short answer is yes, but some people have had the reverse happen. I'm going to use several different formulations on some scrap mahogany to see what happens. Both resins have been used in the fine arts fields for a really long time.
Author:  crazymanmichael [ Fri Feb 09, 2007 3:36 pm ]
i think they are added more for toughness rather than hardness. plain french polish is quite hard, but can be brittle. varnishes with a host of additives, including copal and sandarac, have been developed to make the finish tougher, more flexible without losing the inherent hardness so as not to inhibit tone, responsiveness, yadda, yadda. reading some of the violin makers recipes is an education in itself.
Author:  TRein [ Sat Feb 10, 2007 6:49 am ]
BTW, a really good bottle to keep your walnut oil in is an empty Jet Dry (dishwashing rinse aid) bottle. It has a tiny opening that works well for putting a drop of oil on the pad.
Author:  burbank [ Sat Feb 10, 2007 8:39 am ]
Hesh,
Another down side to masking the bridge and fb areas with fp is that it
makes for a bit of a bother during the fp process. It's nicer to have as much
area clear as is possible when the muneca is flying around on the top.
Author:  jhowell [ Sat Feb 10, 2007 8:43 am ]
Hesh--
I made a scraper from a single edged razor blade by burnishing it on a screwdriver. It turned out to be very controllable. Didn't make me nearly as nervous as putting the lam trimmer on the guitar to route the bindings.
